350D radiator leaking
skeetertom
Post by skeetertom » Tue Mar 15, 2011 4:55 pm
Just got a 350D and it has a leak from the radiator. What is involved in removing this radiator? Took a quick look before dark but was not sure how much needs to come apart. Thanks for any help :cry:
vestor_guy
Post by vestor_guy » Tue Mar 15, 2011 6:54 pm
the hood and front shroud has to come off. You will need an engine hoist for the front shroud.
skeetertom
Post by skeetertom » Fri Mar 18, 2011 8:39 pm
Thanks I got it fixed for $80, tank was worn thru from a loose shroud. All back together and no leaks. Job went well with two of us and a mini excavator to lift the shroud.
bonker81
Post by bonker81 » Sat Mar 19, 2011 7:25 am
The front shroud actually pivots on two pins at the bottom. You need to remove 3 bolts down low on each side (5/8 or 3/4 if I remember correctly) and then 4 or 5 bolts underneath that connect to the belly pan. With those out it will pivot forward out of your way and stay there safely. I did this when I pulled my radiator, no need to completely remove it. After that, as long as nothing is too rusted up, it comes out easy.
1970 350 with a 93A backhoe attachment
Users browsing this forum: No registered users and 253 guests
