450c quit, now smokes
Flatheadyoungin
Post by Flatheadyoungin » Fri May 14, 2010 12:22 pm
http://www.jdcrawlers.com/messageboard/ ... php?t=4650
http://www.jdcrawlers.com/messageboard/ ... ector+pump
http://www.jdcrawlers.com/messageboard/ ... ght=#22264
if you can find jdemaris link to where he stores his pictures, he has some exploded views...i can't find them right now
there's someone on here that posted about DO NOT take it apart according to the manual......i'm pretty sure it has you take it apart from the end opposite the engine side (where your lines come out and go to the injectors) if you do this is when you loose time in the injector....
you must start by removing the top cover (which is where the solenoid is located).......
i'd order a seal kit and a solenoid for it and put only the solenoid and the top oring seal in it.....even though your's looks wet enough that it could use the rest of the seal kit.....
it REALLY isn't that bad to do......once you've had one all apart, you aren't scared of them any more.......but, before you start, you think you should call NASA for help........
i'm rambling but i can't really type a lot right now...
mtodd101
Post by mtodd101 » Fri May 14, 2010 3:08 pm
Hey Flathead. You guys are getting closer, but still a ways to go. I'm in western Washington. 40 miles north of Seattle. Any documentation you could show me would be much appreciated. I've been going to the links you provided and seeing some good stuff. Thanks. I have seen jdemaris's pictures. I don't remember seeing my particular pump model, but also good info.Thanks Matt
OneWelder
Post by OneWelder » Sun May 16, 2010 5:26 pm
I have not done this in years - but as I remember it you could just take cover off with pump on engine , a few screws -
Flatheadyoungin
Post by Flatheadyoungin » Sun May 16, 2010 7:33 pm
I'm sorry I didn't get back to your sooner. Life threw me a curve ball that I would have never expected, so my priorities aren't the same.
I looked on my CPU here at home. I don't seem to have the .PDF file of for the pump. It must be at work. Send me your email address and I'll try to send it to you. Will your email account hold a 50 megabyte file? I think it's really about 40 megabytes, but I sure don't remember.......
My factory JD service manuals has a good pic of the solenoid in it. If I have to, I can take a photo of it and post it up.
It's easy, just take that top cover off and there it is. I think it's just 4 bolts. Nothing should jump out at you or go flying across the room! ahahaha
Injector pumps, for the most part, are usually for rocket scientist. Most people's first response, is "...you just have to send it off, no one can fix them." And, many can't/wouldn't etc. but after many of the folks here and other sites, the parts, at least for mine, was VERY fixable and wasn't too bad of a job to boot.
mtodd101 wrote:Hey Flathead. You guys are getting closer, but still a ways to go. I'm in western Washington. 40 miles north of Seattle. Any documentation you could show me would be much appreciated. I've been going to the links you provided and seeing some good stuff. Thanks. I have seen jdemaris's pictures. I don't remember seeing my particular pump model, but also good info.Thanks Matt
Flatheadyoungin
Post by Flatheadyoungin » Mon May 17, 2010 8:44 am
it's 25 megabytes
mtodd101
Post by mtodd101 » Mon May 17, 2010 9:18 am
Hey Flathead. I sent you a private message. Not sure if you got it. My email is 250 mb so shouldn't be a problem. Here's my email. Thanks again. Matt
mtodd101@whidbey.com
Flatheadyoungin
Post by Flatheadyoungin » Tue May 18, 2010 5:57 am
i tried 3 different email accounts; gmail, roadrunner and yahoo...... the file is like 26.8 meg.....the all have limits of 25....i can't split the file, as far as i know....
it would be much slower, but i could just print the section you need and mail it to you....i owe it to the karma bank, other people have done this for me over the years of reading on the internet...
MattE
Post by MattE » Tue May 18, 2010 9:08 am
Flathead,
you could upload a file that size to a file sharing site like photobucket.com
then link it to the forum here
Flatheadyoungin
Post by Flatheadyoungin » Tue May 18, 2010 10:26 am
well, i just went there and tried the process....photobucket, when you upload files, doesn't even see the .pdf file to be able to select it and upload it.....
mtodd101
Post by mtodd101 » Fri May 21, 2010 10:12 am
Hi Flathead. I appreciated your effort. I still haven't made any attempt to dismantle anything. Is there a way that you could copy and paste the pages that i would need into an email or if I sent you a CD disk, could you put the pdf file on it an return it to me? Thanks again. Matt
Flatheadyoungin
Post by Flatheadyoungin » Mon May 24, 2010 10:25 am
i could put it in the mail on a disc......PM me your address.....be patient with me, i've still got some crazy stuff going on and we just got another curve ball.....
mtodd101
Post by mtodd101 » Tue May 25, 2010 12:17 am
Thanks Flathead. I sent you an email. Matt
wjptcs
Post by wjptcs » Wed May 26, 2010 11:03 am
There is also a free program called Drop Box that you can set up to share files. I use it every day for work and home as well as sharing files between employees.
Flatheadyoungin
Post by Flatheadyoungin » Fri May 28, 2010 8:54 am
PM me your address.....i don't see the email in any of my accounts....
also, i may install that file sharing site....
mtodd101
Post by mtodd101 » Thu Jun 10, 2010 9:05 pm
Hey flathead. Hope things are going ok for you. I was wondering if you were able to get that pdf file working. Still haven't done anything with my 450. It's been raining so much that I'm not inclined to go outside and work on it yet. Thanks again for everyones help. I'll post with some pics when I get around to working on the shut off solenoid. Matt
Users browsing this forum: No registered users and 181 guests
