450 C bad reverse 1984 model
What is wrong with a 1984 450 C loader when it will not pull in reverse after it gets warmed up good. It pulls in all forward gears good all day but after about 1 hour of running it will not move at all in reverse. Tired of going around in circles. Hope me out...
mine wouldn't back up to save it's life....it put me in a pretty bad position on a hill one day...
i replaced both hydraulic filters, one in front of the radiator (hadn't been changed in who knows when) and i pulled the one in the tank resevoir and it had ruptured out the side......
haven't had a problem since....
Where is the other one at besides the one in font of the radiator.?Flatheadyoungin wrote:mine wouldn't back up to save it's life....it put me in a pretty bad position on a hill one day...
filters on 45 C
holedigger wrote:Where is the other one at besides the one in font of the radiator.?Flatheadyoungin wrote:mine wouldn't back up to save it's life....it put me in a pretty bad position on a hill one day...
Does anyone know where the other filter is besides the one in front of the radiator.?
Thanks. I will try that this weekend. I have never changed that one so maybe that will solve the problem.Flatheadyoungin wrote:if you are sitting in the seat, under your right elbow.....it's not a spin on...
raise the access panel, it's inside the oil tank...you have to remove several bolts to get to it.....
be sure to get an extra gasket, just in case you tear it......if i remember right...
Well I changed the oil and filter in the hydraulic tank and it didn't affect the transmission. It still will not pull in reverse after about1 hour of running. It still pulls forward real good.I was told that under the 2 floor board panels are a rubber plugs and one has a 15/16 bolt under it. Does this adjust the transmission pump and if so how do you do it.?tuney443 wrote:If it is indeed just the filters,change your hyd. oil also.
Users browsing this forum: Google Adsense [Bot], Johntc23 and 315 guests
