Reverser Drain Plug Stripped
NickC
Post by NickC » Sun Nov 01, 2009 11:12 am
All,
You guys have been great, helping me get my 350 back in good condition.
In changing fluid in the reverser, I found the drain plug, a surprisingly small (3/8") allen plug, frozen in place and irremovable because it had been previously rounded out. It looks like my only option now is to drill it out and attempt to remove the remainder or re-tap the hole for a larger plug. Am I doing the right thing here? Is there a better way to approach this?
Thanks again,
Nick
BSims66173
Post by BSims66173 » Sun Nov 01, 2009 1:01 pm
Might look at getting a nut just large enough to fit over the plug, weld it to the plug and use a wrench or socket to get it out. I have done that on many rounded off bolts.
NickC
Post by NickC » Sun Nov 01, 2009 1:19 pm
Excellent suggestion. Not being a welder, it didn't occur to me. I'll ask my buddy to try that tomorrow. Thanks.
mikeintn
Post by mikeintn » Sun Nov 01, 2009 1:43 pm
Yes that can work, I did it about 2 weeks ago on my reverser, welded a nut on it and it came right out :D
Michael
NickC
Post by NickC » Sun Nov 01, 2009 9:37 pm
Why is there such a tiny little drain plug in that case? There's 3 gallons of oil in there! The trans has a 1/2" plug with a 9 quart capacity. Strange.
Users browsing this forum: No registered users and 315 guests
