I am finally starting work on the steering clutch that has been not working for over two years. I have had a couple of attempts at it, but for one reason or another I gave up on it.
I now have my machine sitting on axles stands (4 x 6tons each) so the tracks, when tightened are well clear of the concrete floor (board removed for now).
I have previously tried to get the master pin out using heat, but it didn't work. Yesterday I slackened off the screw on the track tensioner and have bled out all the grease I can - the front wheel moves back just about two and half inches. I had hoped to be able to get the track to slip over the rear sprocket and then proceed from there, to remove sprocket, cover and intermediate shaft. That idea has been tried but I couldn't get the track over the rear sprocket
I guess I must now go back and try the proper method of seperating the track at the masterlink - using heat and a tool holder for the punch. Maybe I can get lucky this time.
Unfortunately the master link is the opposite to where oit should be at the rear of the machine. The hyd.tank- fuel tank combo is off the machine - I cannot run the engine to move the track as no hydraulics (cook pump- clutch rusted in engaged position)). Can the track be pulled around using a set of chain falls - pulling the length of the track , maybe 6 ft? Would the starter be strong enough to move the tracks - machine off the ground?
I am trying not to have to re-install the fuel/hyd tanks again as I working on my own and would like to keep the work as little involved as possible.
If any of you guys have some ideas I would appreciate hearing them. I need to get this machine up and running properly, by the end of the month. Cost is a big factor (retired) and I am having watch everything I spend these days
Thanks in advance
mariiner
