350 reverser
mikeintn
350 reverser
Post by mikeintn » Wed Sep 23, 2009 6:02 pm
I took reverser apart the clutches looks good does anyone know of a measurement for the wear limit, and is it normal for the metal ones to have some blue place on them? Thanks
Michael
BSims66173
Post by BSims66173 » Fri Sep 25, 2009 3:57 pm
I have 1 new clutch and one new plate that I can measure for you if you need it.
Barry
Post by digitup2 » Fri Sep 25, 2009 4:03 pm
Replace all surfaces and steels because the blue is from heat and those surfaces are also done rebuild the clutch pack properly at this point also look at the piston and replace it if the seal area is a slight bit wore out This is some times the culprit of the slipping clutch in the first place as the leaking oil will let the pressure drop and the clutch slips burning the steels blue and creating enough heat to warp them or burn them leaving them useless and in need of replacement also .So replace the friction plates the steels and a good close look at the piston sleeve area will also need to be done to see if this is the root to the problem these pistons are expensive but are some times the whole problem to begin with .Digitup.
mikeintn
Post by mikeintn » Sat Sep 26, 2009 6:44 am
Thanks for the info. and Barry I would like the thickness of the new clutch if you will.
Michael
BSims66173
Post by BSims66173 » Sat Sep 26, 2009 8:32 pm
will post readings in the morning. Been watching football all day and forgot to check forum until now.
mikeintn
Post by mikeintn » Sun Sep 27, 2009 8:59 am
Ok
Michael
BSims66173
Post by BSims66173 » Sun Sep 27, 2009 8:59 am
New Clutch thickness reading is .113 and the plate thickness is .062. I hope this helps.
Barry
mikeintn
Post by mikeintn » Sun Sep 27, 2009 9:18 am
Yes thanks Barry.
Michael
Users browsing this forum: Google Adsense [Bot] and 248 guests
