350 flywheel and isolator question
typhoon0003
Post by typhoon0003 » Fri Aug 28, 2009 6:36 pm
for all of those that have upgraded to the 350d flywheel and isolator, is it possible to modify the old style flywheel on a lathe ( or mill if needed) to accept the new style isolator? thanks for any help.
gene s
Post by gene s » Fri Aug 28, 2009 8:26 pm
I would say no, you'd have to remove way too much material from the old flywheel, if you'd even want to, wouldn't be worth trying it.
MF40, MF30,350B
dustin502
Post by dustin502 » Sat Aug 29, 2009 9:40 am
The 350D Flywheel is Thicker and alot heavier.
57 Allis Chalmers D14
59 Allis Chalmers D14
Mustang 940 skidsteer
JD350B dozer
mikeintn
Post by mikeintn » Tue Sep 01, 2009 8:00 pm
If you go to your local JD dealer to upgrade to the 350D, and they dont know every thing you need for the job, what would you need to tell them that you need, how many pieces are there that it takes to do the change over.
Michael
gene s
Post by gene s » Wed Sep 02, 2009 7:51 am
You would hope the parts guy can look it up, but anyway what you will need is a new flywheel and the new isolator. The new isolator is one piece, no springs and stuff like the old style.
MF40, MF30,350B
