HELP!!! reverser problems
CBroerman
Post by CBroerman » Tue May 12, 2009 11:16 am
Ok well our reverser has been whining so i did some checking and the dip stick up by the brake pedal (im guessing that this is the reverser) is EMPTY and the one by the shifter/left turning lever (also guessing is the tranny) is DOUBLE what is should have in it... Is there a seal inbetwine them that has gone bad and drained all the oil from one into the other???
Also the number plate says that it is a 350CE, what does the "CE" stand for? any help would be greatly apriciated
2004 New Holland compact backhoe
1979 John Deere 350C
jdemaris
Re: HELP!!! reverser problems
Post by jdemaris » Tue May 12, 2009 5:08 pm
CBroerman wrote:Is there a seal inbetwine them that has gone bad and drained all the oil from one into the other???
Yes, it's a common issue with C-series 350s. The hydraulic steering clutch packs are powered by the reverser. When they leak, the reverser pumps all its oil into the transmission.
CBroerman
Post by CBroerman » Tue May 12, 2009 5:53 pm
Ok, how much of a job is it to change the seals? Do they regularly go bad or from sitting alot. What kind of oil does the reverser take? Also does anyone know where we can get a shop manual for this 350C?
Thank you
KenP
Post by KenP » Tue May 12, 2009 6:32 pm
deleted
CBroerman
Post by CBroerman » Tue May 12, 2009 7:14 pm
Ok, Thank you very much for your help. We just ordered a shop manual and an opperators manual. Wow there near and dear haha
KenP
Post by KenP » Wed May 13, 2009 4:11 am
deleted.
CBroerman
Post by CBroerman » Wed May 13, 2009 6:56 pm
Yea just gotta bite the bullit. But how often do these seals go bad? It has done alot of sitting. Its a 79 350c with 925 hrs. its the original hr meter and the machine is TIGHT. so is has sat alot...
Users browsing this forum: No registered users and 132 guests
