440’s at work
jimmydiesel
Re: 440’s at work
Post by jimmydiesel » Fri Dec 19, 2025 12:37 pm
dtoots1
A 6 way blade is a big advantage if doing more than just pushing material. You could put a blade on your loader frame.
This picture shows my 440IC 831. It has a fork lift attatcment that has the manual 6 way blade from a model 63 dozer adapted to it.
This picture shows a 420 crawler loader with an outside blade operated by the loader hydraulics
I have a 440Ic 831 with a blown engine that will get a 2-53 swapped in and mounts for a 602 dozer added. It will be like the 420 shown above.
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
Re: 440’s at work
Post by Lavoy » Fri Dec 19, 2025 7:24 pm
I have a couple of factory doze4 blade attachments for the loaders.
jimmydiesel
Re: 440’s at work
Post by jimmydiesel » Sun Dec 21, 2025 12:33 pm
For someone that has a crawler loader a blade attachment would be a great attachment to have.
440 ICD 831 Loader
440IC 831 Loader
jimmydiesel
Re: 440’s at work
Post by jimmydiesel » Wed Feb 04, 2026 7:25 pm
50 degrees today. Good day to do a little dozing.
440ICD 602.
440 ICD 831 Loader
440IC 831 Loader
Re: 440’s at work
Post by Stan Disbrow » Thu Feb 05, 2026 8:51 am
Nice!
It is 30 degrees here today and yesterday in NC with high humidity and a Duke's Mixture precip. So, I am doing a different kind of dozing. :P
jimmydiesel
Re: 440’s at work
Post by jimmydiesel » Thu Mar 05, 2026 9:29 am
Warmer than usual weather continues here in the west.
440 ICD 831 Loader
440IC 831 Loader
jimmydiesel
Re: 440’s at work
Post by jimmydiesel » Mon Mar 30, 2026 9:50 pm
After sitting for 4 years with the left final drive apart, I finally got this 440ICD 602 3 point hitch back together in November. It has Berco 350 rails (chains) and weld on sprocket rims. The engine is upgraded to “N” series parts. It is a strong runner.
We have put 15 hours on it fixing a few oil leaks and other minor problems. Will be moving it 60 miles to my cousins place so she can fill in and level up around here place.
440 ICD 831 Loader
440IC 831 Loader
