440 ICD restoration
johndeere4402-53
Post by johndeere4402-53 » Tue May 26, 2015 1:29 pm
Only have the lift cylinder hooked up because we painted it literally 2hrs before we put it on. the dozer still has the toolboxes to go on and a few other little htings like the belly pans touch it up in a couple of spots
shinnery
Post by shinnery » Tue May 26, 2015 11:02 pm
I just have to wonder how well it will push dirt with the dozer blade and basically street tracks. Those tracks are more designed for a loader and turning all the time versus digging with the dozer. Of course I am assuming you try to work it.
whiteclipse16
Post by whiteclipse16 » Thu May 28, 2015 5:30 am
Assuming you used the John Deere "Old Construction Yellow" paint, how many gallons did it take you. I think it took me roughly 5 gallons. That yellow sure doesn't go far.
Ben
johndeere4402-53
Post by johndeere4402-53 » Thu May 28, 2015 8:20 am
It was like 4 gallon but will probaly be about 5 when done the yellow is different all over
johndeere4402-53
Post by johndeere4402-53 » Sat Jul 18, 2015 10:19 am
whiteclipse16
Post by whiteclipse16 » Sun Jul 19, 2015 3:57 pm
What is the larger tube sticking out the underneath of the machine. I assume the small one is from the air box vent.
Are you running the original electric oil pressure gauge for a diesel. They're impossible to find.
Ben
johndeere4402-53
Post by johndeere4402-53 » Sun Jul 19, 2015 7:20 pm
whiteclipse16 wrote:What is the larger tube sticking out the underneath of the machine. I assume the small one is from the air box vent.
Where running a napa one but it wont let enough amps through to charge with lights in my opinion but we havent ran it the larger tube it the drain for our slobber tank so it dont make a mess
whiteclipse16
Post by whiteclipse16 » Mon Jul 20, 2015 6:52 am
You must elaborate more on this "slobber tank" because mine slobbers like a 1 year old cutting teeth sometimes. It's odd, sometimes I can run it an hour or so and get no slobber. I noticed the other day my dad ran it and there was some slobber. I'm thinking he probably was babying it, running low RPMs, and that may be why.
Where is the tank mounted, how is it connected, etc. etc.
Ben
Post by Stan Disbrow » Mon Jul 20, 2015 7:19 am
The ammeter won't be the reason you aren't getting enough current to balance the load of the lights. That will be the generator not making enough current. And, that will be a weak field either from the regulator or within the generator itself.
Of course, how much running will you be doing with the lights on?
My 420c generator is weak, too. It has just about enough for two lights, not enough for three, even at high RPM. So, I disconnected the dim rear as it is unnecessary and so it only burns the two front lights in the 'D' position as a result. Still, it is rare that I ever need any lights, so the weakness doesn't matter much.
Now, when I lived up North and had snow to plow, lights were used quite often. Here, not so much. Pretty much never, actually.
johndeere4402-53
Post by johndeere4402-53 » Mon Jul 20, 2015 2:02 pm
Probaly wont use the lights much at all the tank is just to keep it from dripping i dont have any pics but we made it so you can drain it every so often.
johndeere4402-53
Post by johndeere4402-53 » Mon Jul 20, 2015 2:04 pm
ddaxe
Post by ddaxe » Wed Oct 14, 2015 7:46 am
beautiful work.. Sir... your thread has inspired me to tackle my 440..
Chrome don't getcha Home
johndeere4402-53
Post by johndeere4402-53 » Wed Oct 14, 2015 8:46 am
Thanks I'd like to find a 440 diesel tractor next
JWB Contracting
440 industrial
Post by JWB Contracting » Wed Oct 14, 2015 7:44 pm
I just got one with a loader, three point hitch and reverser but unfortunately it is a gas. It's original and rough but all there. Does run and work good, but rear hubs are loose. Most likely going to have to glue them on with deacon, but not until I fix the brakes.
Never seen a diesel one around here.
Planning on using it for snow removal as my new acerage has a paved driveway. Not this winter, have other projects already slated for this winter.
Les
Post by Les » Thu Oct 15, 2015 10:12 am
Wow! You've done what I would love to do some day with my 450B. Awesome job! One question though; would it be worth it to bead blast and powder coat the parts versus any other spray method...assuming one had a large bake oven available?
Les
1971 450B Crawler Dozer
