Post
by JD440ICD2006 » Sat Feb 06, 2010 5:59 pm
I found this generator that came off of a 420. I am rebuilding it with all new parts and converting it to 12 volt output for my 440IC. It will look exactly like the original generator including tag and numbers when I finish.
It will be painted JD Old Construction Yellow.
[/img]
Post
by JD440ICD2006 » Sat Feb 06, 2010 9:40 pm
Waiting for the new "guts" to get here so I can rebuild it. It will be a brand new generator converted to 12 volts.
KenP
Post
by KenP » Sun Feb 07, 2010 6:07 am
deleted
KenP on Sun May 26, 2013 4:15 pm, edited 1 time in total.
Post
by JD440ICD2006 » Sun Feb 07, 2010 6:42 am
That is a great idea, I had not really considered that. I saw some "12 V" decals somewhere, I will try to locate them and place them on it in a place that cannot be seen when it is mounted on the 440 IC.
Post
by JD440ICD2006 » Wed Feb 10, 2010 10:23 am
Parts came in and in the process of putting it all back together.
New brushes, end shaft bushing, metal oiler & 12 volt armature
New bearing, felt, metal oiler, etc.
New 12 volt coils, insulators, output post, etc.
Post
by mini kahuna » Wed Feb 10, 2010 5:33 pm
you are doing a fantastic job with it,looking like an oem new part.
Post
by Ray III » Wed Feb 10, 2010 6:51 pm
Looks good. I thought it was nearly impossible to get some of the parts, or is that a different story if the internals are for 12 volt?
I painted mine up nice like that, except I made it Delco-Remy colors with a black body and red tag. I know it ain't right, but I don't agree with Deere blasting everything with their own color.
Post
by JD440ICD2006 » Wed Feb 10, 2010 7:41 pm
Finished product, just needs some touch up on the paint.
The only sad part is that it will likely still be running when I am not.
- Site Admin
Post
by Lavoy » Thu Feb 11, 2010 10:48 am
Now it's time for halogen headlights and a really bitchin stereo system!
Post
by JD440ICD2006 » Thu Feb 11, 2010 11:02 am
The halogen headlights would be nice but a stereo system may drown out the great sound of the Dubuque two cyclinder engine. Now that would be a pure shame!
It can seriously pull some better headlights now with 12 volts.
