claude murwin
Post
by claude murwin » Thu Aug 06, 2009 7:05 pm
looks like a farmall f12/f14 , just a guess, another fun project anyway
1010 dozer,750,dozer,2010 tractor,ac d17,vac case
Dave Seager
Post
by Dave Seager » Fri Aug 07, 2009 8:23 pm
Farmall F-14. Note the raised steering wheel and shaft. F-12 would have the wheel and shaft lower and parallel to the top of the hood and fuel tank.
HTH, Dave
Dave Seager
Pine Hill Farm
57 Highland Rd
New Boston, NH 03070
(603) 487-3640
The Fireman
Post
by The Fireman » Mon Aug 10, 2009 10:50 pm
The steering shaft is from a Farmall F-14 however looking at the brake levers I see pipes added to them to give some extra height. This indicates that it is an f-12 the F-14 had the angled steering shaft and longer brake handles, both to improve operator comfort. I removed the farm added pipes from the brake levers on my F-12 and they are definatly more difficult to to get to.
the serial number plate should be located on the front fuel tank support it will give the serial number, modle number and rated engine speed. When everything is right these tractors will start with 2-3 puls on the crank. aftermarket parts are availibe and arent overly expensive. Not to mention the size makes them easy to work on, everything is pretty light and manigable.
- Site Admin
Post
by Lavoy » Tue Aug 11, 2009 9:11 am
The F14 we have has an odd looking doohicky sticking up in the middle of the hood with fuel lines running to it. The tractor is at the farm, or I would post pics.
Pammark
Post
by Pammark » Tue Aug 11, 2009 1:16 pm
I think the tractor is an F-12. I have one just like it. Note the open universal joint between the engine and tranny. Years ago ours belonged to the neighbor man. He alwys had large dogs and one day while the tractor was idling, the dog ran under the tractor and the universal grabbed the tail and ripped it off. I am sure the dog had a squeel after that. Well anyway, from then on we always said, "This tractor eats dog tails for lunch."
Mark
JD 2010 Crawler with Loader
fixedforever
Post
by fixedforever » Tue Aug 11, 2009 9:52 pm
It is a 1936 f12. Its forsale, best offer takes it.
1010 Gas Crawler sold
2010 diesel crawler loader
fixedforever
Post
by fixedforever » Sun Oct 25, 2009 8:22 pm
I am going to try to fix this tractor tomorrow. It has no spark, it has a magnedo, any tips on repairing this?
- Site Admin
Post
by Lavoy » Mon Oct 26, 2009 9:30 am
You can try points and condenser, beyond that, I have them repaired, there seems to be a little black magic involved with making mags work.
fixedforever
Post
by fixedforever » Fri Dec 25, 2009 9:07 pm
I am almost done fixing this F12 tractor, It's missing the air filter. Does anyone know where I can get one?
