Post
by wwattson » Fri Jan 02, 2009 9:56 pm
Well, sharing my love for 1010 crawlers like my friend Lavoy, I've been off and on fighting getting the four broken off bolts for about as long as I've had the machine apart. I'm not smarter than a 1010 but I'm quite a bit meaner than most of them.
There is a saying that there were few social problem that a couple of pounds of strategically placed C-4 can't solve. As it turns out, there's not much that a Bridgeport mill an a new solid carbide end mill won't cut out of a 1010 track frame.
Die Stupid Bolts!!!
Bill
Lu47Dan
Post
by Lu47Dan » Fri Jan 02, 2009 10:35 pm
Bill , A Bridgeport would be right handy for that
I have seen stranger stuff set up in them around here . I have been thinking of buying a Bridgeport for some time now , and since buying the 420 , it has became more then thinking . Machine shop rates going up and the machinist I use being busier than a cat burying s&it on a hot tin roof , one might magically appear in the shop to keep the lathe and my surface grinder company .
. After all I will have the RPC built by the end of the month . Dan
1956 420C with GSC blade
