2-53 engine at a tractor pull
pop pop
Post by pop pop » Sun Aug 02, 2026 4:54 am
remembering when i saw a 2-53 Detroit in tractor pull at the Arizona state fair around about 1999 , it was in a 420 ?? wide front.
The man had won in his class and upon speaking to him , found out he had it tuned to produce 63 HP, :shock:
The event was held inside one of the metal livestock barns, all the other engines seemed quiet compared to the screamin jimmy, :lol:
I can describe it as , a 55 gallon drum being hammered at the rate of several thousand rpm. The actual exhaust noise was echoing off the tin roof and looked like a large roman candle. As near as i can guess, he was spinning those fully lugged ag tires at a rate ~75mph.
it was the JD from hell. :twisted:
Re: 2-53 engine at a tractor pull
Post by Jim B » Sun Aug 02, 2026 7:03 am
The John Deere 435, diesel version of the gas 430, was the ag tractor that had the 2-53 as the OEM engine. The 440ID was the industrial version of the 435 with the 2-53.
Post by Stan Disbrow » Sun Aug 02, 2026 7:13 am
The 435 was intended to use the extra power out the PTO shaft. They tended to wear out the ring and pinion gears when that power was used for pulling. That was the same back half as the 420w and 430w. IIRC the 440IC sported heavier gears than the 435 did.
I spent a lot of time on a 435 with a 1000 RPM PTO running a three-string small square baler when I was a teenager. The sound was like an industrial vacuum cleaner. ;) But that rig baled as fast as a 4010 could and was a lot more maneuverable.
jimmydiesel
Post by jimmydiesel » Sun Aug 02, 2026 5:34 pm
There is a few you tube videos of 440 and 435’s pulling.
https://www.youtube.com/watch?v=sXMPnlkdYKI
This is a nice 440 pulling. There is other videos of this one on you tube
435 making a pull inside.
https://www.youtube.com/watch?v=rkH4KtT_sb0
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
jimmydiesel
Post by jimmydiesel » Mon Aug 17, 2026 6:16 pm
440 ICD 831 Loader
440IC 831 Loader
Users browsing this forum: No registered users and 89 guests
