Posts for Pic Server requests and comments
Greetings,
For anyone with comments, concerns, and/or requests regarding the dedicated pic server please place them here. Lavoy or myself will monitor and follow up.
For any member desiring an account to load pics (and I hope it's all of you) please pass me a pm with a user name and a password you wish to use. Please make the password is at least 8 characters with upper (at least 1) and lower case, letters and numbers, and at least one symbol.
You can find out more about the pic server here: viewtopic.php?f=5&t=11788
Leverage, it's what's for dinner!
60 Cat D6B dozer
?? JD 350b crawler/loader
02 JD 260 Skid Steer
68 Case 580CK diesel w/backhoe
67 Case 580CK Gas w/backhoe
81 JLG S35 scissor lift
Clark C500-70, C500-30, GCX40 forklifts
81 Intl 1854 dump
60 Cat D6B dozer
81 Intl 1854 dump
Re: Posts for Pic Server requests and comments
o.k. that looks like will be real nice!!
i took a peek....and find that cannot look at the bigger pics from your mini's.....guess that each person wanting to view needs to have password for that particular site....just to view pics??? or do the pics actually appear in the story line?
dtoots1
dtoots1
Good point dtools1. I hadn't checked that. Take a look again... should see thumbnail, intermediate, and original now.
60 Cat D6B dozer
81 Intl 1854 dump
60 Cat D6B dozer
81 Intl 1854 dump
How do we get our username/password added to the pic server?
It is stated in the first post at the top of this page....
to register you must send a private message or email with your login and password to hdokes or lavoy.....then you should also read the Q&A section which is located at the bottom of the "Board index", Q&A only appears on the board index when you have logged into the jdcrawler site....
read all the posts in the Q&A session.
If you have problems post them and we will get answers back to you...
ALSO...to get to the private message board...click on the link next to your login link at upper right .....also every post has their owners pm at the extreme right of the post...it can be clicked on. when logged in and you have received a pm (your private message link) it will be highlighted in red.l
- 440 iron popper
Is there a way to have the picture displayed in the post or do we always have to click the link to go at it?
Thanks.
Thanks.
440ironpopper,
what you do is post a hyperlink in your post...that is the image link just above this message (when in edit mode or when typing your post)...it is the 9th block above and kinda looks like a pic. Insert the pic file number directly after...url,, of your photo preceded by normal_ this limits the pic to a version that does not utilize the full screen. note clicking on the pic in your message will NOT enable a larger version ....the pic server itself saves 3 different sizes small, medium and larger.
((and YES the pic can be shown using the image link but that also has to include all of the info shown in the text line below, so it knows where to get it, in effect the entire hyperlink))
OKAY, now to actually have the pic in the post...you must insert the entire hyperlink as outlined below directly after the 2 slashes...and your pic appears in post when you submit the post.......look at the Q&A forum to see where to click on the dedicated pic server..
Lets try to make this simpler
....gonna cheat a bit...simply copy and past the hyperlink shown below this paragraph the number directly after /userpics/
is assigned for you by the computer (if shown, if none shown in your file, ignore it) include normal_ copy and paste the pic number and submit your post.
OK because it shown as hyper line your cannot copy till i make it only text...you will then simply copy and paste the text and then add at the beginning the http with the : and the // which makes it a hyperlink
jdcrawlers.lcent.com:8000/johndeere/albums/userpics/10004/normal_IMG_20170110_141405_450~0.jpg
below is where i used the image button and added the hyperlink....oops maybe not yet..i had added a space and had to edit out!!!
i am gonna go back again and do so momentarily directly under this line...
http://jdcrawlers.lcent.com:8000/johnde ... _450~0.jpg
as you can see directly above i simply added the hyperlink info to the statement..much simpler.
for info...the first part of link directs computer to where pics are stored
i may have to edit this to get that just exact..gotta go back and look after i submit this. (NOW BACK TO EDIT)
***try again..http://jdcrawlers.lcent.com:8000/johnde ... _450~0.jpg ..it works!***
YOUCAN IGNORE THE FOLLOWING is just explanation info.
//jdcrawlers.lcent.com:8000/johndeere/albums/userpics/10004/normal_IMG_20170110_141405_450~0.jpg
IMG_20170110_141405_450~0.jpg ..copied and pasted from pic editor file name...
as you may notice the 2 above read the same..but the edit file for the pic shows "img" in caps as noted in line directly above this sentence...it will not work unless exactly shown in the pic editor file name...
- 440 iron popper
Test!
I think I get it now
It looks like it works better with a laptop running Windows than a ipad from apple. Will do some more testing and probably re-edit some show and tell posts.
Thanks Dtoots1 for your advices!
you got it...it is just one step less to simply type the hyperlink and then click on it view the pic..
glad to do it...
welcome aboard!!! nice machine
glad to do it...
- 440 iron popper
That makes the post more interesting as well.
It would be nicer with a 64 blade
Work in progress...!
one quickie.....in the pic server if you choose the 440 album to upload your pics to...they will all be in your OWN album, but others can view them or whatever machine group you have. the one yours got into is kind of a open info type.
just to get this back to top of board and more noticeable to others...
anyone having problems posting pics???? if so post here and will get back to walk you thru.
Would it be possible to have a 430 group to post to?
Thanks,
Bill
Thanks,
Bill
430 John Deere Crawler
You can set up your own gallery for your photos if you want to get some posted, before there is a 430 gallery. You will see a number of personal galleries there, mine included, as some photos might not be model specific.
How is best and easiest way to log into dedicated pic site. After many tries, I finally went to your post in Q&A and wolla- there it is. Is that the only way to log into pic site?
I am not very computer literate, so anything that makes it easier for me sure helps.
