ISO Loader forks
E.Huffman
ISO Loader forks
Post by E.Huffman » Sat Feb 12, 2022 10:38 am
I am looking for loader forks for a john deere #90 loader or quiktach and maybe even a set I could modify to fit. it does need to have a backplate.
gus
Re: ISO Loader forks
Post by gus » Sat Feb 12, 2022 12:09 pm
Are you replacing the bucket with forks or getting the ones that slide over the bottom of the bucket and clamp on? Lots of the clamp on type.
E.Huffman
Post by E.Huffman » Mon Feb 14, 2022 8:13 am
I will be taking the bucket off I am planning to haul up to 3000 pounds with it. Bucket clamp on forks wont hold up to the rough use compared to a set of forks with a frame
gus
Post by gus » Tue Feb 15, 2022 12:05 pm
Possibly buy the front frame and forks off of a junkyard forklift? Wouldn't be to hard to adapt it to the loader frame.
E.Huffman
Post by E.Huffman » Tue Feb 22, 2022 7:34 am
That would work if I could find em
mty
Post by mty » Fri Feb 25, 2022 8:18 pm
What models used the 90 loader ?
JD350-C 6 way dozer, JD 5400, JD1025E
Post by Lavoy » Sat Feb 26, 2022 7:44 pm
420/430
gus
Post by gus » Sat Mar 19, 2022 1:59 pm
If\when you get this made. Post how you do it. I have a 420 with loader that's on my list for the next rebuild and I might also like to use it for lifting with forks.
E.Huffman
Post by E.Huffman » Wed Mar 23, 2022 3:27 pm
Ok I will try to! I hope to do it this year..
