1010C Gas for sale
1010C Gas for sale
1010C gas for sale. Runs great w/rebuilt carb. Radiator redone with the cooler in the bottom tank. 6 way hydraulic blade w/original joystick valve. Linkage rebuilt on the valve and have the spool kit also. Engine was taken out to put in a new bushing on the reverser input shaft, and engine put back in. I drove it in to the shop before starting but it will need the steering clutches done along with all that goes along with that job. Pads, rails, and rollers decent. Moving and no time to finish. A good start for someone to finish and use it. Good tag. $1650 Buffalo NY 716-866-4700
430C,62 Blade
1947 Lindeman w/Tool Carrier & Blade
1964 1010C w/ 612 Dozer
- milesofmike
Re: 1010C Gas for sale
Do you have any pictures? Does it run well enough to drive onto a trailer?
196x JD 1010 Crawler Loader
