For Sale 350 Diesel with 6 way blade
Crawler runs and moves but will not steer. Reverser seems to work ok. Tracks are toast. Does have some oil leaks. Blade seems to work ok. Needs an ignition switch as the previous owner used a screw driver to turn the key switch. I wired straight to the shut off on the pump as the switch seems intermittent. I bought this in this condition and I don't know much more about it. The floor plate was removed, but I have it and will go with it. No PTO. I can send pics if anyone is interested. Asking $2750 Located at zip 44836.
