Tranny/Differential overhaul
zahnje
Post by zahnje » Thu Sep 28, 2006 6:51 pm
:) Hi Guys,
Got the tranny/rear end seperated from my 440 ICD. Now, how available are the seals, bearings, shims and all the good stuff I should replace while it is disassembled. At first glance all the gears look good and the ring and pinion gears were not an issue prior to disassembly. Are the parts I need available from John Deere or would it be better to cross them over and get them from somewhere else...maybe from Little Shop O' Deeres??? If there is a source please advise, I would appreciate it.
Thanks in advance,
JimZ.
Post by Lavoy » Thu Sep 28, 2006 9:37 pm
Jim,
Most or all should cross to after market as far as bearings, shims will be Deere item only.
