I am selling off the above titled piece from 420C #125053. I originally was going to restore this one as it was bought with another one but I found a 430C and want to turn my attention to it instead.
I rebuilt the tranny with all new bearings, races, and seals/gaskets.
I rebuilt the diff section also the same way and set the ring and pinion to factory spec when I installed the side quills.
The reverser got all the little thrust bearings and washers and new seals and is bolted to the tranny.
The housing was hot tanked when apart and blasted and primed.
The "Torque Tube/Bellhousing" is also available and I rebushed the pedal shafts and blasted and primed.
I would prefer to not seperate the tranny and reverser unless I have a buyer for both
My cell is 716-866-4700 and I am in the Buffalo NY area.
Tons of stuff from the 420C also so if you need something else let me know. I do have a couple of pics.
Super,super nice 420C complete grille/nose.
Rebuilt 5 Speed Trans w/Gear Style Reverser
430C,62 Blade
1947 Lindeman w/Tool Carrier & Blade
1964 1010C w/ 612 Dozer
