J.D. 40C part needed
drew43a
Post by drew43a » Sat May 29, 2010 3:43 pm
I am looking for one of those cast iron V mounting brackets. Used on the undercarrage in a few differant spots. Its V shaped with two ears with a hole in each ear. Dont know what the parts is called. I need one someone has got a home made welded bracket in place now.
Thanks andrew
Post by Lavoy » Sat May 29, 2010 9:59 pm
I should have them on hand.
drew43a
parts
Post by drew43a » Sun May 30, 2010 9:59 am
Might you have the two caps that are under the seat ? on each side. i think he has oil drum caps screwed in there now.
Post by Lavoy » Sun May 30, 2010 3:08 pm
Tri-sure bung plugs is what came in from the factory, so yours might be correct.
drew43a
parts
Post by drew43a » Mon May 31, 2010 5:00 am
AAHHH i looked closer. One is original the other is not. Do you have original ones? and do you have that v block part also? what is the price? I keep finding things i need, might be better to call.
thanks andy
Post by Lavoy » Mon May 31, 2010 8:31 am
Andy,
My cell is 701-361-1006, my computer crashed, so I can't do e-mail for the moment. If you want to e-mail me, go ahead, it might be a couple days until I can get back to you.
