2010 crawler serial numbers
CHA011
Post by CHA011 » Mon Nov 02, 2009 6:16 pm
Lavoy- exactly were do I look for the serial number of the machine. I assume it is on the bellhousing. Bottom line I would like to find it. :D
Post by Lavoy » Mon Nov 02, 2009 11:03 pm
Early crawlers are on the RH front side of the engine block, later crawlers on the LH side of the bellhousing.
CHA011
Can non important subjects be deleted and who can
Post by CHA011 » Fri Nov 06, 2009 5:16 pm
Lavoy wrote:Early crawlers are on the RH front side of the engine block, later crawlers on the LH side of the bellhousing.
You may delete this posting
Post by Lavoy » Sat Nov 07, 2009 6:06 pm
Anyone can delete their own posting, in the upper RH corner there is an "X", that is delete.
raceyalater
2010 serial
Post by raceyalater » Wed Jan 06, 2010 10:45 am
Is the serial number on a tag or is it stamped/cast into the casting? Thanks
Post by Lavoy » Wed Jan 06, 2010 10:45 am
Always on a metal tag.
raceyalater
2010 serial
Post by raceyalater » Wed Jan 06, 2010 11:01 am
Well I guess mine is missing. It looks like it was supposed to be right front on the engine block, there are two rivets there. What years am I potentially looking at for this machine. Thanks
Re: 2010 serial
Post by Tigerhaze » Wed Jan 06, 2010 12:18 pm
raceyalater wrote:What years am I potentially looking at for this machine. Thanks
My understanding is the serial number break between early and late 2010 crawlers is considered to be 42,000 (this was changeover for larger track pins and bushings, etc). Serial number 42,000 occurred in model year 1964, so your machine would likely be between 1962 and 1964 (no crawlers produced in 1960 or 1961).
I am not sure if 42,000 is also when they switched over from tags on the engines to the bellhousing, but Lavoy could confirm that.
This website is where I got the serial number information:
http://www.johnnypopper.com/weirddeere/ ... Wheel.html
There are other clues to serial number range (fuel injector setup for diesels, etc.) that can narrow down the earlier 2010 crawlers. The parts book is very helpful for that.
Don't feel bad- my first 2010 didn't have the serial number plate either. While it is a problem if you want to make a collectible or plan on transporting often, it really doesn't impact ability to get the correct parts or the functionality.
