Yellow 3 roller 40 for sale
Post by Lavoy » Mon Jun 22, 2009 9:06 am
For Sale: Industrial Yellow 3 roller 40 crawler, 14" pads, no blade, has hydraulics, 14" pads. This crawler has not come in the shop yet, but will be shortly. Call or e-mail if you are interested.
Thanks,
Post by Lavoy » Tue Sep 08, 2009 8:24 am
Okay, shortly ended up being longer than I thought, but it is here now. I will have it in the shop this afternoon is anyone wants pics.
pop pop
converting no hydraulic to hydraulic on 40's
Post by pop pop » Tue Sep 08, 2009 10:02 pm
was wondering about the 40's with no hydraulics.(1953 model)
can they be converted simply?
has anyone put on an alternate hydraulic system?,,, like a different pump run from other than a stock setup?
i see some models had a secondary unit coming out of the rear,, ,,, is it possible to add this models secondary or might the castings or something else render it unfeasible?,,this crawler has the 540 pto,,,
Post by Lavoy » Wed Sep 09, 2009 9:22 am
Factory hydraulics can be added, you just need to parts to do it. You could put something like a Prince PTO pump on the back, but you will not have live hyd then. You would also need a reservoir, and a valve with a bypass in it. I have seen pumps mounted on the front and driven off the crankshaft, but usually they butcher the sheetmetal when doing so.
Post by Lavoy » Fri Oct 02, 2009 7:59 am
Okay, finally was able to get some time in on the 40. The crawler will have new fibers and steels on both sides, pressure plates were already new I found when I got it apart. It has excellent undercarriage, 14" single bar grousers, hyd, good sheetmetal. Have not had it runnning yet, fuel tank is at the rad shop getting steamcleaned, should have it next week. Also will be putting on new muffler, carb kit, and tune-up parts.
sellcl
3 roller
Post by sellcl » Fri Oct 09, 2009 11:19 am
do you still have this crawler? and if you do send me some pictures. sellcl@uwec.edu
Post by Lavoy » Wed Oct 21, 2009 9:28 am
The crawler is sold, thank you to all who inquired.
