jd 2010 diesel
jd 2010 diesel
hi does any body need a2010 motor and what is the value ? motor is complete when i bought it they claimed it ran good ? thanks chubbs
Value of the engine depends quite a bit on condition and amount of wear. The value also depends what you mean by "complete"- does it have water pump, injectors, injector pump, etc. or strictly block with oil pan and head?
I may have some interest depending on your location- where are you at Chubbs?
