MC track pads
MC track pads
Would Lavoy or anyone else have access to stamped steel, 14" wide , 2 bolt track pads for my 1950 MC?. I do have 28 of the heavy pads located thru Ralph in Grants Pass Oregon, but could use 28 more of them to change the full set. Thanks Dennis
- FarmLife
- Contact:
THere is a parts crawler on e-bay right now with what looks to be 14" pads, which you could probably run off with pretty cheap. THere may only be enough pads to make one full set of good ones, but it is worth a look.
Here is e-bay item number 330214814812
1934 GP Beaner
1935 B
1935 AR
1935 AO
1936 B
1936 D
1935 A on skeletons
1937 A w/behlen overdrive
1939 B
1940 B
1941 H
1949 M
1954 40 Standard
1953 60 Regular
1955 70 Std Diesel
1954 80
1946 Lindeman
Phase 1 420
1935 B
1935 AR
1935 AO
1936 B
1936 D
1935 A on skeletons
1939 B
1940 B
1941 H
1949 M
1954 40 Standard
1953 60 Regular
1955 70 Std Diesel
1954 80
1946 Lindeman
Phase 1 420
