Model 420 hydraulic blade question.
mc40joe
Post by mc40joe » Thu Oct 23, 2014 8:36 pm
Is there an adjustment on the control valves so you may stop blade at any height?
Post by Lavoy » Thu Oct 23, 2014 9:55 pm
Not sure I understand the question? When you let go of the hyd lever, the blade should stop moving no matter where it is at.
mc40joe
Post by mc40joe » Fri Oct 24, 2014 7:25 am
when you let go of the handle unless it at the top it goes back down. model 420 c with heavy duty blade
Post by Lavoy » Fri Oct 24, 2014 8:17 am
Usually that is bad cylinder seals, either way, not a setting on the valve.
mc40joe
Post by mc40joe » Fri Oct 24, 2014 11:48 am
thank you it has two cylinders on it should both be rebuilt
Post by Stan Disbrow » Fri Oct 24, 2014 2:07 pm
Yes, since each cylinder only has about the capacity to lift half of the blade weight on a 62 (the model number of the bulldozer attachment).
mc40joe
Post by mc40joe » Fri Oct 24, 2014 2:26 pm
thank you for the help are there kits for them from deere or any one you know
Post by Lavoy » Fri Oct 24, 2014 4:03 pm
Check with a local hyd shop, if not, give me a call.
mc40joe
Post by mc40joe » Sat Oct 25, 2014 8:13 am
OK THANK YOU FOR YOUR HELP
Users browsing this forum: No registered users and 264 guests
