Tins for MC crawler
tbird505
Tins for MC crawler
Post by tbird505 » Wed Jan 25, 2006 8:04 pm
I am in need of a decent grille, left side foot pan (rest). For an MC crawler .Not for show ,just decent. Also when I push the clutch in, the brake pedal on the right side also goes down. I amassuming that they should be independant. Is the brake just frozen on the shaft? Thanks in advance. Paul
Post by Lavoy » Wed Jan 25, 2006 9:43 pm
Paul,
Actually it is the clutch pedal that is frozenon the shaft. Sometimes you can take the brake pedal off, and pound the shaft to the left and get it lubed up enough to work.
tbird505
MC tins
Post by tbird505 » Thu Jan 26, 2006 6:06 pm
THANKS LAVOY ,BY THE WAY, A WHILE AGO YOU TOLD ME HOW TO ADJUST THE STEERING CLUTCHES ON AN MC. I HEATED UP A 1/2 '' WRENCH ,BENT IT AND WAS ABLE TO MAKE THE ADJUSTMENT. AFTER A FEW TRIES I WAS ABLE TO GET IT TO STEER GREAT THANK YOU FOR THE ADVICE. PAUL
