So I have finally pulled my grandpa's old 440 out of the shed and decided to make it run. Well it starts and runs perfect, it's the under carriage that is the problem. I have read a lot of posts about replacing/ updating the undercarriage. After taking a look I can see that my chains need to be replaced (accouple of the links are worn so bad that they are partially broken. and the drive sprockets are very, very worn as well as the pins and bushings being warn through.) My question is, I have read that you can use 350 chain and weld 350 sprocket teeth on the 440. But are the rollers and front idler the same? or will I need to change these as well. I am sure I will have a lot more questions as I go forward but one step at a time. I would appreciate any input.
R/s
Josh
Reviving a '59 440 ICD
- jimmydiesel
Re: Reviving a '59 440 ICD
I have a 440 ICD with 350 chains and 350 sprocket rims welded to the cut down 440 sprocket.
It still has 440 rollers and front Idler.
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
440 ICD 831 Loader
440IC 831 Loader
Awesome Thank you very much for the reply. I am starting to take it apart next week. I appreciate the help.
Josh
Josh
- jimmydiesel
The 350 chains that I have use 4 bolt pads.
440 ICD 831 Loader
440IC 831 Loader
440 ICD 831 Loader
440IC 831 Loader
Users browsing this forum: jimmydiesel and 30 guests
