Smoke in hydraulic tank and 2 psi oil pressure
jperry3223
Post by jperry3223 » Fri Mar 17, 2017 12:26 pm
I have a 420c with smoke coming out of the hydraulic tank. The hydraulics work fine and have 800 psi on piston lockup. I also have 1 to 2 psi on the new 0 to 30 psi oil pressure gauge. Thanks
notmeu
Re: Smoke in hydraulic tank and 2 psi oil pressure
Post by notmeu » Fri Mar 17, 2017 4:57 pm
Just a shot in the dark. But is your hydraulic oil getting hot and boiling some moisture out of the fluid. Does your fluid look milky.
Surely there is no smoke coming from the engine thru the pump. If thats the case your engine would be full of hydraulic oil.
jperry3223
Post by jperry3223 » Fri Mar 17, 2017 5:40 pm
Yes, white color of fluid, but seems to be cool to the touch.
Post by Lavoy » Fri Mar 17, 2017 11:10 pm
White is water.
notmeu
Post by notmeu » Sat Mar 18, 2017 9:58 am
I would start with draining the hydraulic fluid out of the tank and pull the cylinders and manually drain out the fluids for each cylinder by pulling the cylinder rod back and forth to try and get as much of the milky fluid out of the hydraulic system as possible.
jperry3223
Post by jperry3223 » Sat Mar 18, 2017 1:34 pm
In the process of draining the hydraulic oil and replacing it.
Any thoughts on the low oil pressure? Bad oil pump ? Bypass open in the oil filter housing ? Broken oil pump gear ?
gregjo1948
Post by gregjo1948 » Sun Mar 19, 2017 3:32 am
Blockage in oil pressure line?
jperry3223
Post by jperry3223 » Sun Mar 19, 2017 8:34 am
The oil pressure gauge is on the filter housing.
Post by Stan Disbrow » Sun Mar 19, 2017 10:10 am
Piece of an old gasket fall in and block the passage to the gauge?
I am kind of reaching there. Sounds like you have a serious issue....
Anyone work on the insides of that engine latey? Might have the oil pump timing out of whack. Also, if no work lately, might be a clogged up inlet screen on the oil pump.
jperry3223
Post by jperry3223 » Sun Mar 19, 2017 10:18 am
Hi Stan. I just removed the oil filter assembly and only a trickle of oil came out while a short running of the motor.
I took out the oil pump it looks ok. The gears have a wee bit of slop and the end cover is smooth, no gouges.
Jay
Users browsing this forum: No registered users and 194 guests
