Looking for help on what transmissions/housings will work on my crawler. My serial number tag is MIA when I rescued the crawler from my grandpa after sitting abandoned for 30+ years, and when I got it home I noticed the trans housing is cracked on both sides. I found a complete transmission/bell housing local here in Indiana. The trans I found has a casting number of M3432T, which is different than mine. Will any jd40 trans work? Is there somewhere I can cross reference what casting numbers are compatible?
Thanks in abvance for any help!
40c transmission compatibility
Crawler only, wheel tractors have different gears even if the case is the same.
Users browsing this forum: No registered users and 194 guests
