Governor spacer
FarmLife
Governor spacer
Post by FarmLife » Sat Oct 27, 2007 3:27 pm
The spacer that goes between the governor weights and the fork connected the the governor rod. First off are both ends of that spacer supposed to turn and if only one end is supposed to turn which way is it supposed to go. The non turning end against the governor weights, or the ther way around. Or is that spacer just froze up and I need a new one. Thanks for the help.
1934 GP Beaner
1935 B
1935 AR
1935 AO
1936 B
1936 D
1935 A on skeletons
1937 A w/behlen overdrive
1939 B
1940 B
1941 H
1949 M
1954 40 Standard
1953 60 Regular
1955 70 Std Diesel
1954 80
1946 Lindeman
Phase 1 420
Post by Lavoy » Sat Oct 27, 2007 8:28 pm
I think what you are referring to is the governor thrust bearing. If neither end will turn, you need a new one or damage will result.
FarmLife
Post by FarmLife » Sat Oct 27, 2007 11:32 pm
What I have now the one end will turn freely but the other end rotates with the center section of the thurst bearing. What I understand both ends should turn independently of the center section. Lavoy do you have these available cause I am having a feeling I will be needing one that works correctly.
1934 GP Beaner
1935 B
1935 AR
1935 AO
1936 B
1936 D
1935 A on skeletons
1939 B
1940 B
1941 H
1949 M
1954 40 Standard
1953 60 Regular
1955 70 Std Diesel
1954 80
1946 Lindeman
Phase 1 420
Post by Lavoy » Sun Oct 28, 2007 3:23 pm
No, yours is correct, one end rotates, one end is staionary. The governor rotates, the forks do not, so only one end rotates so to speak.
FarmLife
Post by FarmLife » Sun Oct 28, 2007 8:28 pm
ok thst's good, as usual thanks for the excellent information
1934 GP Beaner
1935 B
1935 AR
1935 AO
1936 B
1936 D
1935 A on skeletons
1939 B
1940 B
1941 H
1949 M
1954 40 Standard
1953 60 Regular
1955 70 Std Diesel
1954 80
1946 Lindeman
Phase 1 420
Users browsing this forum: jimmydiesel and 199 guests
