Best tool for the job
DozerAndy
Post by DozerAndy » Tue Sep 18, 2007 7:05 pm
Looks like I’m going to have purchase or rent a gear puller for pulling final drive and pinion gears. Looking through northern tool, there doesn’t seem to be anything similar to that shown in the Deere Manual. Does anyone have a recommendation for a gear puller for pulling final drive gears and pinion gears in the 420 and 440 crawlers?
Post by Lavoy » Tue Sep 18, 2007 9:23 pm
The bull gear requires a "T" bar puller, and you push the axle out of the bull gear.
As far as pinion gear, I have never needed one, but I have had to cut the outer bearing off or heat it up to get it off.
DozerAndy
Post by DozerAndy » Wed Sep 19, 2007 7:08 am
Thanks Lavoy. Since I will probably end up pulling at least 4 in the next year or two (both crawlers), would it be cheaper to rent or buy? Does anyone have a favorite brand that doesn't cost an arm and a leg?
Post by Lavoy » Wed Sep 19, 2007 7:37 am
I don't think the puller I bought was that expensive, but I don't remember for sure.
Stretch
Post by Stretch » Wed Sep 19, 2007 4:35 pm
OTC makes about the best pullers I've seen, and I believe they make them for everyone else.
Stretch
2010C Dozer, 2010C Loader
emmett
Hammer and punch to disass
Post by emmett » Wed Sep 19, 2007 5:58 pm
On my 420C final drive...
I got my pinion gear off with a hammer and punch. I disconnect the final drive housing from the transmission housing. Remove the cover from the final drive shaft. Remove the c-clip (ring) from the end of the drive shaft (next to the pinion gear outer bearing). Then I put a punch in the shaft-end indent and smack it with my 40 ounce ball-peen. Bearing pops right off.
Bull gear is the same story. Except I took the oil pan off the main housing. Took 3 c-clamps and clamped the bull gear against the housing. 2 clamps on either end of the oilpan gasket surface. 1 clamp thru the pinion gear hole.
Smacked the flanged axle end and the bull gear gave way as the axle pushed out. It was so easy I figure I don't need the c-clamps next time. (I was kinda worried that I would crack the cast housing, but it was OK.)
I would have rented a gear puller for the bull gear, but somebody welded the access plug to the bull gear's tapped holes in a previous repair to the housing. Now that I know the bull gear comes off so easily, I'll probably use the hammer & punch technique from here on.
Emmett
420C Crawler 1957 w/ blade & army 6x6 winch
DozerAndy
Post by DozerAndy » Sat Sep 22, 2007 1:15 pm
Thanks for all the good info. I'm going to need a new pinion gear. Luckily, I do have a spare bull gear ($$$).
