Sizing battery
old dutchmen
Re: Sizing battery
Post by old dutchmen » Sun Dec 07, 2025 9:47 pm
I think I understand. You put a silicone pad heater on the oil pan to warm the oil and then you installed something like a Kat's heater to warm the coolant which then warms the block. I assume you drilled out the taped hole where the drain valve is to increase the inlet to the Kats. I guess I could just make a new plate to replace the "football shaped piece" with a taped hole. Where did you tap into the coolant for the return?
Thank you for trying to teach me about your solution.
Re: Sizing battery
Post by Lavoy » Mon Dec 08, 2025 10:57 am
Kind of, I use a larger pad heater, 250 watts or so, then you get additional heat in the block from the warm oil. I have an immersion heater that threads into the plates I made, I just had trouble threading them, so had not made any in a while.
Re: Sizing battery
Post by Stan Disbrow » Tue Dec 09, 2025 8:21 am
There is always my North Country of New York State solution. Crawler under the shed roof, LP (or kero) jet engine heater. Fire that up under the drawbar aimed at the open back end of the belly pan. Head back to the house for another cup of coffee. Heats it all finals to radiator. Air intake too.
I got the idea from an old early tractor manual which directed one to build a fire under the machine, ;)
Anyway, used when it snowed overnight and it was plowing time. Worked just fine on the '68 350. I don't need it now in North Carolina. First off, it doesn't get that cold and it doesn't snow that much anyway.
gus
Re: Sizing battery
Post by gus » Tue Dec 09, 2025 12:20 pm
Helps to throw a tarp over the front end too. Helps raise temperature on everything.
old dutchmen
Re: Sizing battery
Post by old dutchmen » Tue Dec 09, 2025 5:58 pm
Thanks. It was 10 degrees this morning in Pennsylvania. I thought about using your method
Good to hear it works. I'll give it a try. Planning to butcher a steer in February and need to make sure my crawler starts!
jimmydiesel
Re: Sizing battery
Post by jimmydiesel » Fri Dec 12, 2025 10:32 pm
“ Where did you tap into the coolant for the return?“
old dutchman
There was a tank heater available as an option from John Deere. Electric or LP gas. It returned the heated coolant to the plate on the back of the cylinder head.
The other hole is for the temperature sending unit.
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
old dutchmen
Re: Sizing battery
Post by old dutchmen » Mon Dec 15, 2025 7:56 am
That's interesting
Thanks.
