1010c Rebuild thread
reedgmi
Post by reedgmi » Mon Sep 08, 2025 7:14 pm
It started simple enough. My son came home at Christmas, and said "Dad, you need a dozer". Obviously, I answered "I do?" And the chain reaction started....
He had found a very cute Deere machine. I have restored a couple of old tractors, but this crawler stuff is a bit new to me. I thought it was decent shape, but I misjudged. I could see the front idlers were worn, so I knew that would be a task. Once I got it home, I realised the track carriers had a lot of wear with the cross shafts. Then I saw that the clutch housing was cracked, because bolts were loose and missing. Finally, I figured out every structural fastener was compromised somehow. I guess someone got lazy with re-assembly, perhaps after the engine replacement.
By this time, I was too deep into it to back out. And it is cute, worth saving. A gallon or two of paint is going to work wonders.
So here we are : the point of maximum disassembly. Going to clean this up a bit more, then paint it before the frosty nights start. Then piece by piece, things will get cleaned/rebuilt/repaired/pained/reassembled. No set timeline.
Going to be an adventure .... will document in this thread.
1963 (?) Deere 1010 Crawler-Dozer
1955 Ford 850
1973 MF40 Ind
reedgmi
Re: 1010c Rebuild thread
Post by reedgmi » Tue Sep 16, 2025 6:42 pm
Big milestone today! 2 coats of epoxy primer on the main chassis & frame rails. Took longer than I wanted to source the clutch housing, replacing a cracked one. Would have been nice to have painted with the final drives already assembled, but too much work to do on them still, and didn't want to miss the great outdoor-painting weather we've been having in Michigan. Top coat tomorrow.
1955 Ford 850
1973 MF40 Ind
reedgmi
Post by reedgmi » Thu Sep 18, 2025 4:55 am
1st round of painting done! I used Deere paint, even though I'm not a big fan of spraying alkyd enamels. Interestingly, the recommended "Deere Paint Thinner" is no longer available, at least in Michigan. Replaced by a low-VOC version, which is just acetone. But Chat GBT came to the rescue, and suggested that original Deere thinner is 50% Mineral Spirits, 30% Naptha, 20% Xylene. For warmer weather, it was suggested to modify to 60% Mineral Spirits, 20% Naptha, 20% Xylene. So that's what I mixed up and used - at a ratio of 10:1. I sprayed 3 coats, which used about 1/2 gal of paint.
A lot of components still to clean, repair & paint, but this was the big one of course.
1955 Ford 850
1973 MF40 Ind
reedgmi
Post by reedgmi » Sat Sep 27, 2025 4:58 pm
Got a coat of primer on my next batch of parts - which included the hydraulic pump - only to spot fluid seeping around the pump body. I knew it had been leaking, but thought it was the shaft seal. Tore it down, only to find a disaster inside. Heavy scoring of the body, well past the wear limits for every dimension listed in the manual.
I figured out these pumps are a standard SAE Type A, CCW, around 13 GPM. So I bought a generic gear pump, 1.71 cu in/rev, for $150. Should be 13 GPM @ 1800 rpm.
1955 Ford 850
1973 MF40 Ind
reedgmi
Post by reedgmi » Sun Sep 28, 2025 7:15 pm
The fun continues. I knew there was trouble with the left side final drive already - saw the small pieces of clutch plate when I removed it.
Half of the friction plates had the ears that engage with the input shaft sheared off. The brake drum had a big wobble. End play for the final drive shaft measured in inches, not thou!
Sure enough, that final drive shaft roller bearing pair was utterly destroyed. The pinion gear not looking to hot either. Surprisingly, the larger bull gear only suffered minor damage, from what I can see. For anyone looking, the bearings are standard parts : 18590/18520 for the larger inboard one & 15123/15245 for the smaller outboard one.
1955 Ford 850
1973 MF40 Ind
gus
Post by gus » Sun Sep 28, 2025 10:53 pm
When I opened the rear cover on my 420 and started cleaning around the ring/pinion gears I heard a clunk in the drain pan. I thought there's no clunk in oil! Then another and another and another.... there were 2 bolts still holding the ring gear on and one was loose.
Same in about every place I opened. I would suggest you look in every assembly. It's easier now than if it's together and fails.
reedgmi
Post by reedgmi » Mon Sep 29, 2025 6:31 am
I know what you are saying. In hindsight, I should have taken a deeper dive into the transmission. But everything is painted now. I may regret, but hopefully not! I really wish this machine had an original hour meter & owner record. I would be fascinated to know the history that got it to the current condition.
1955 Ford 850
1973 MF40 Ind
gus
Post by gus » Mon Sep 29, 2025 2:31 pm
If it has a reverser, I would definitely check it out completely. That was a check that definitely saved my butt from a major problem.
reedgmi
Post by reedgmi » Mon Sep 29, 2025 5:38 pm
What issue did you have with the reverser?
1955 Ford 850
1973 MF40 Ind
gus
Post by gus » Fri Oct 03, 2025 9:11 am
Several, thrust bearing was shot, bearing retainer was moving, retainer roll pin was sheared off.
Keep in mind, my reverser is manual gear shift, not hydraulic. Yours is likely very different but subject to different potential problems. There's pretty regular questions regarding them posted here.
