1952 MC crawler
fundytides
Re: 1952 MC crawler
Post by fundytides » Mon Jun 16, 2025 8:09 pm
My 40c starter will jam once in a while. I find that if I loosen the nut and tapered bolt that locks the starter in place and then pry the starter away from the flywheel a bit, the bendix will usually come free. Shove the starter back in place, install and tighten the bolt and lock nut and away it goes. Good luck!
roadbuilder
Re: 1952 MC crawler
Post by roadbuilder » Sat Jun 21, 2025 8:25 am
Thanks Lavoy,
Still doing hay, and haven't pulled the starter yet.
My friend thats is interested in it has offered to come down and help "tinker" with it.
Just so I know going in....How much for a starter? And I expect also a switch?
If it's worth doin', it's worth doin' right.
roadbuilder
Re: 1952 MC crawler
Post by roadbuilder » Sat Jun 21, 2025 8:30 am
Thank you Fundytides!
Re: 1952 MC crawler
Post by Lavoy » Mon Jun 23, 2025 8:50 am
Starter is $400 + freight, switch is already installed.
roadbuilder
Re: 1952 MC crawler
Post by roadbuilder » Mon Jun 23, 2025 10:27 pm
Thanks Lavoy,
How about an ignition switch?
Re: 1952 MC crawler
Post by Lavoy » Tue Jun 24, 2025 11:02 am
Sorry, misunderstood, thought you meant the switch on the starter.
Ignition switch is $40, no lever.
