1010 track rails
bob1010
1010 track rails
Post by bob1010 » Fri Aug 31, 2007 2:00 pm
Does anyone know were you can buy new rails minus the pins and rollers.
Thanks for any info.
Post by Lavoy » Fri Aug 31, 2007 3:37 pm
I assume you mean minus the pins and bushings? If so, Deere should have some left, but I would guess over $100 per link half. How many do you need, I have some new, and a few used.
Post by wwattson » Fri Aug 31, 2007 5:42 pm
The links aren't coming up on jdparts.com anymore but the last time I looked they were $68 per link side. Working the math for a 4 roller set that comes out to about $8800 for a set of rails from Deere. If it's a 5 roller, make it $9800. Add in the Deere pins and bushings and you're up to $10,400 and $11,600 respectively.
I think I'd look for a used set with some wear left.
Stretch
Post by Stretch » Sun Sep 02, 2007 4:38 am
Bill,
I got new rails complete for my 2010 from JD this past spring and the total price for both sides was $3600.00.
I'm not sure but I think the only difference in the rails for a 1010 and 2010 are the length. 2010 has more links.
Stretch
2010C Dozer, 2010C Loader
Post by Lavoy » Sun Sep 02, 2007 8:37 am
The rails you got were 350 rails which are larger. All 1010's, and 2010's up to serial number 42,000 used 1" pin rails. 2010's after 42,000 switched to 1 1/8" pin rails, which was the same as what came out on 350's.
2010 is indeed 3 links longer than a 1010.
Users browsing this forum: No registered users and 223 guests
