zahnje
Post
by zahnje » Fri Aug 19, 2005 6:54 pm
I am trying to adjust the reverser, rear clutch engagement. I open the access but find no lock pin at the adjustment nut to release. Won't turn either. Is it possible that someone was in there and installed it backwards and it's on the opposite side? Is it possible to install backwards? If so is there any way or tool or method to release it. I fear the worst...disassembly!
JimZ.
- Site Admin
Post
by Lavoy » Fri Aug 19, 2005 9:10 pm
Jim,
It is possible to install it 1/3 of a turn off. Get a mirror and look real close before you disassemble. Also, in a pinch, you can pull the shifter cover and see a little bit.
Users browsing this forum: Google Adsense [Bot] and 26 guests
