1010 exchange
Wilbur
1010 exchange
Post by Wilbur » Thu Aug 15, 2024 10:09 am
Will the engine from a 1010 industrial rubber tired yellow tractor fit my 1010 crawler exactly?
1959 440 icd 831 loader
1961 1010 dozer
Re: 1010 exchange
Post by Jim B » Fri Aug 16, 2024 5:33 am
I believe the base engines will interchange, there may be differences in the engine accessories. You can go to JDparts.com and bring up the parts catalogs for the tractor and your crawler and compare components.
Wilbur
Re: 1010 exchange
Post by Wilbur » Tue Aug 20, 2024 5:30 am
Thanks Jim B! Been after main bearing for the 1010 for over a year with no luck. Can't believe John Deere abandoned their equipment.
1961 1010 dozer
Re: 1010 exchange
Post by Stan Disbrow » Tue Aug 20, 2024 6:57 am
Deere does better than any other company I know of when it comes to parts availability. Most other things wind up unobtainium at 10 years as the normal mode of operation. But there has to be a time limit at some point.
The 1010 dates back to 1960, is of a design not repeated with subsequent models (such as the 1020 which is totally different) and had a fairly short production time. Especially that engine.
Hurlbutt
Re: 1010 exchange
Post by Hurlbutt » Tue Aug 20, 2024 1:36 pm
From what I have read in postings here, the water pump is unique to the crawler.
Bill
Re: 1010 exchange
Post by Lavoy » Wed Aug 21, 2024 7:34 pm
Water pump is different, also possibly manifold.
Users browsing this forum: No registered users and 20 guests
