Gearmatic 8a needs Parts and Manual
Marty here. I recently acquired a 1957 Case 310. I know its not a JD but it shares the Gearmatic 8a winch. Its in great shape and with very little work has been building ski trails. I wanted to switch to pulling logs around and was surprised to open the right side of the 8a and find all the clutch components missing and brake band in bad shape. I thought it would be easier to find an old JD with this winch but i am struggling to do so. Does anybody have parts. Lavoy i noticed you did about a year ago. I would post photos but have to learn how. I have also reached out to three sources for a manual but no luck yet. I would love a PDF manual sent to staceynmarty@gmail.com if possible.
Thanks in advance
Marty
Thanks in advance
Marty
Re: Gearmatic 8a needs Parts and Manual
I have some parts, yes.
- jimmydiesel
I sent you a pdf of the manual. It was sent to me from Paul Buhler.
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
440 ICD 831 Loader
440IC 831 Loader
Thank you. Paul sent one as well. I have been jibbering with him through email. I am searching your archives for bearing cross references but that is only delaying finding all the clutch and brake guts as mine were not at home when i opened the door.
I can probably figure out some of what you need without part numbers, give me a call some time.
- Hambrick28
I would like to get the manual as well if anyone has one. Lanceandmakenzie28@gmail.com thank you ahead of time
1959 John Deere 440icd 6 way hydraulic blade,
1959 John Deere 440icd No blade
Tom on here sent me a bearing cross reference once if you still want it.
Last year I posted where to find clutch bands, but they are expensive and want the cores back if you have any.
I would like to get the manual as well please aguenette.1@outlook.com
Ok I did find it and here it is
https://www.dropbox.com/scl/fi/8eb4tapc ... jrpcc&dl=0
I still have the bearing cross reference if anyone needs it. I can email it to you or it is also online. Tom
https://magazin-rulmenti-online.ro/wp-c ... erence.pdf
Users browsing this forum: Google Adsense [Bot] and 22 guests
