420c starting problems
Turkeyeyes25
Post by Turkeyeyes25 » Sun Dec 18, 2022 2:38 pm
Long story short crawler wouldn't start, changed plugs wires cap rotor points and condenser. Fired right up. Ran well for an hour then died. Rebuilt carb as it was traced down to a fuel issue. Now I can't get it to idle or even stay firing for more than 3 seconds and it has to be full choke. Puffs black smoke fires couple times and dies. Tried adjusting float levels up higher and still nothing. Will mention it only ran before with choke 1/4 closed. Anyone have any ideas? I gave up and purchased a new carburetor completely but waiting on shipping.
gus
Re: 420c starting problems
Post by gus » Sun Dec 18, 2022 5:36 pm
Cleaned the little screen where the fuel line attaches to the carb? Mine was nearly plugged.
Post by Jim B » Sun Dec 18, 2022 6:23 pm
Venturi in upside down?
Did you use top cleaners, or such, to run into all the ports as part of the rebuild?
dtoots1
Post by dtoots1 » Mon Dec 19, 2022 7:35 pm
Sounds to me like dirt and debri in carb...maybe water?...Is tank clean??...also helps to know your location...you can provide that in the drop down box where you log in to the site...click on profile and add location
Post by Lavoy » Tue Dec 20, 2022 9:04 am
What all did you do for the carb rebuild?
Users browsing this forum: Google Adsense [Bot] and 23 guests
