2-53 Detroit diesel rear main seal
Hambrick28
Post by Hambrick28 » Fri Oct 28, 2022 11:47 am
Ok I'm having difficulty finding a part number or a specific tool for the 2-53 Detroit diesel rear main. I have tried to install a seal and had no luck, ruined the seal. Problem I'm having is I cant find one that is for the 2-53.
1959 John Deere 440icd 6 way hydraulic blade,
1959 John Deere 440icd No blade
jimmydiesel
Re: 2-53 Detroit diesel rear main seal
Post by jimmydiesel » Fri Oct 28, 2022 6:01 pm
The rear crankshaft seal for the 2-53 is part # 5116229 this is the John Deere and Detroit Diesel number. The same seal is used on the 2-53 3-53 4-53 and 6v53.
If the crankshaft is grooved from the old seal it should have the oversize seal and wear sleeve # 5196852 seal and 5196851 sleeve, installed
The Detroit install tool # j3154-02 only works if the rear cover is off the engine. A hardwood block works for me to install them when the cover is on. You could make a seal driver from a piece of pipe.
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
Hambrick28
Post by Hambrick28 » Wed Feb 08, 2023 12:45 pm
Thanks for the reply. I ended up making a seal driver from pipe and got it in. Thanks for the help.
