fan belt help
jbernd56
fan belt help
Post by jbernd56 » Tue Jul 19, 2022 8:59 am
This is somewhat off topic but here goes. I am working on a 1942 Caterpillar R2 with electric start and generator. Caterpillar still offers the fan belt, but no longer sees fit to have a belt for the generator.
The Cat # is 5B 243. 1 1/16 X 38.5
I was wondering if this would cross to anything you would use. or if anybody had a source to go to for "classic" belts.
I also have a 40C that I will be working on steering clutches on latter, so probably not the last time to be here.
Re: fan belt help
Post by Jim B » Tue Jul 19, 2022 9:53 am
There is a lot of knowledge on this site, so someone may have had this same issue. I checked Gates and they recognize the CAT number, but using the interchange to a Gates belt, says no replacement.
You might consider checking out the Antique Caterpillar Machinery Owners Club. Here is a link to it: https://www.acmoc.org/
jbernd56
Re: fan belt help
Post by jbernd56 » Wed Jul 20, 2022 8:27 am
Thanks Jim, I am aware of ACMOC, been a member many years. Found a "will work" belt at NAPA. Appreciate the quick response .
