Deere 820-2010 Loader Backhoe final drive removal. Lots - O -Rust!
jimmydiesel
Re: Deere 820-2010 Loader Backhoe final drive removal. Lots - O -Rust!
Post by jimmydiesel » Sat Jul 02, 2022 12:20 pm
iowahill1
Master pin and clip look like the picture below.
You could jack the machine up and put 6x6 blocks under the tracks. Leave a space below the master pin big enough to remove the track shoe.Image
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
iowahill1
Post by iowahill1 » Sat Jul 02, 2022 12:40 pm
Yep, that looks like what I have. The tractor is on a paved slope, so I had to crib it up level with some 8 x 16 blocks. There's lot's of slop in the chain and I can lift the track up enough with my forklift to block and remove the two pads. Getting under to pull the clip is next, once the area dries out from the pressure wash. Thanks! -Tom
1981 Ford 555 Backhoe, 1976 International dump truck, 1950 Dodge dump truck, 1990 Link-Belt LS-4300 CII excavator, , Cat D4 7U dozer, John Deere 820/2010 track loader backhoe
"Not knowing what I'm doing has never been a deterrent!"
Post by Lavoy » Sun Jul 03, 2022 7:58 am
Plow bolts are a specific type of head, won't work on track. Grade 5, fine thread bolts, that is what it came from the factory with, OEM is locknuts, I personally never use them, lot less work with regular nuts, just make sure they are tight.
dtoots1
Post by dtoots1 » Sun Jul 03, 2022 12:26 pm
Uf you are blocking up with 8x16 cinder blocks or concrete blocks....NOT RECOMMENDED!!!....they will crush and come down on your head...
Best use solid wood blocks
iowahill1
Post by iowahill1 » Sun Jul 03, 2022 12:43 pm
I got some short wood 8 x 16 blocks from my next-door neighbor that is a heavy equipment operator. I'm also a retired union millwright who knows better, but thank you for the warning. Also, always put wood between metal-to-metal surfaces to keep from slipping (learned that the hard way when I almost had my truck slip off my drive-on hoist, metal chassis on metal hoist lift point). Perhaps others reading this thread will learn something that might save them from harm or death! -Tom
dtoots1
Post by dtoots1 » Mon Jul 04, 2022 6:47 am
That is certainly a relief! Always better to get answers...THANKS
iowahill1
Post by iowahill1 » Tue Jul 05, 2022 8:52 am
Got the master pin out and didn't have to remove the pad and it is 1 1/8" in diameter at the ends, relieved in the middle. Looks like someone had it out but didn't put the clip back on, or it was missing before. The track has 39 links and I assume to be the same as the 350 per a reply from Lavoy to another post. My s/n is 43157. The stock pad bolts are 1/2-13 x 1 3/4", grade 5 partially threaded. So now I need to source a replacement pin with clip. Several photos below:
https://drive.google.com/file/d/1sjYT_u ... sp=sharing (pin location marked with red arrow)
https://drive.google.com/file/d/18OLEZF ... sp=sharing (pin starting to move out with light hammer blows)
https://drive.google.com/file/d/1N2VesX ... sp=sharing (pin out far enough to disengage from link)
https://drive.google.com/file/d/1YN_Ifs ... sp=sharing (track off)
Post by Lavoy » Tue Jul 05, 2022 1:29 pm
I couldn't get the pics to load, but if you have drive master rails, you can't go to a headed master with a snap ring. If you have rails designed for a headed master pin, I should have pins on hand.
iowahill1
Post by iowahill1 » Tue Jul 05, 2022 1:49 pm
This link should bring up one of the four photos of the pin: https://drive.google.com/file/d/1N2VesX ... sp=sharing.
That link is a Google Drive secure URL so you may have to log in to Google. I can't figure out how to post the actual jpg photo just yet. My headed pin looks like the one in the image above provided by jimmiydiesel in an earlier post with the clip. Diameter is 1 1/8" and about 5 1/4" in effective length.
Users browsing this forum: Google Adsense [Bot] and 25 guests
