1010 Radiator
Brad W Wi
1010 Radiator
Post by Brad W Wi » Sun Mar 13, 2022 2:31 pm
I need a 1010 radiator. Any ideas I checked with Lavoy at JDcrawlers with nothing there. it's pretty much roached out.
Re: 1010 Radiator
Post by Jim B » Sun Mar 13, 2022 4:06 pm
Looking at the 1010 crawler parts catalog online, it appears they used 5 different radiators between a serial number break, diesel or gas, and reverser or no reverser. Some (re-cored/reconditioned) turn up doing a web search by the part numbers, but I don't know which one you need. And I can't say if you can use one in place of another. That will take comparing yours with the ones you find.
Here is a link to the online parts catalog so you can review it and determine which yours is. You will first need your serial number to see which side of that break yours is on. If on the high side of the break it becomes gas or diesel, reverser or no reverser. Then with the right radiator number you can Web search by part number.
1010 parts catalog PC727
The other option is to find a shop that can re-core yours.
