1010 Crawler Foot Brake
Re: 1010 Crawler Foot Brake
Post by Paul Buhler » Mon Mar 30, 2020 1:18 pm
If you have the tracks split already, It's not that hard to pull the finals. I used a painter's scaffold on wheels, a sheet of plywood to roll on, and a chain hoist to do mine ( I've also used a pole tripod lashed together with a hoist to manhandle things like this in the past). A manual will be very helpful. Once the final is off, the brake and clutch assemblies and linkages are exposed. The pedal brake linkage adjustments in mine were frozen solid, but with heat and patience, I got mine free, removed, and reassembled. I found "yokes" at a local Ace hardware, but Lavoy probably has a source too. Good luck. Paul
gaspumpsam
Post by gaspumpsam » Mon Mar 30, 2020 7:22 pm
Because the brakes and linkage are so hard to get at, I think I would get one’s from Lavoy, probably way stronger metal.
gaspumpsam
Post by gaspumpsam » Mon Mar 30, 2020 7:26 pm
gaspumpsam
Post by gaspumpsam » Mon Mar 30, 2020 7:28 pm
Don’t know how that happened, but disregard last one :shock: :shock:
Users browsing this forum: No registered users and 167 guests
