retirednhappy
Post
by retirednhappy » Wed May 23, 2007 8:53 am
I have a crawler (Ser. # 113954) with broken teeth on a pinion gear. The dealer says the new part is no longer available so I'm looking for a used one. Anyone have transmission parts available? I love this little tractor and it is indispensible for my tree farm.
- Site Admin
Post
by Lavoy » Wed May 23, 2007 6:21 pm
Are you looking for just the pinion shaft, or the ring and pinion set?
I should have a set in a transmission yet, slight chance I would have just the pinion.
retirednhappy
Post
by retirednhappy » Wed May 23, 2007 7:41 pm
I'll have to get back to you after I contact the dealer again.
Thanks for responding.
retirednhappy
Post
by retirednhappy » Thu May 31, 2007 5:21 pm
Hi Lavoy,
Apparently I just need the ring gear and matching pinion. The part number is M1631T. Let me know if you have it and give me a price.
Thanks,
Steve
- Site Admin
Post
by Lavoy » Thu May 31, 2007 7:27 pm
Steve,
Double check your tooth count just to be safe, I had one just a couple of weeks ago that did not jive with the parts manual. When you get time, send me an e-mail, I don't always catch the posts here.
retirednhappy
Post
by retirednhappy » Fri Jun 08, 2007 9:20 am
Hi Lavoy,
Did you get my email about the teeth? 42 teeth on the gear and 9 on the pinion. Both parts are still in the crawler so counting was a little difficult.
- Site Admin
Post
by Lavoy » Fri Jun 08, 2007 9:46 am
Sorry, I do not have that one, that is an odd combination.
retirednhappy
Post
by retirednhappy » Fri Jun 08, 2007 11:17 am
Do you have any combination of parts that will work? An entire transmission?
Steve
- Site Admin
Post
by Lavoy » Fri Jun 08, 2007 11:26 am
The gear set you have does not appear in the parts books, but I know they made them, I had one just a few months ago. The normal gear set would be 7 and 32 I believe, I may have one of those sets on the shelf, or in a transmission.
retirednhappy
Post
by retirednhappy » Fri Jun 08, 2007 11:48 am
I talked with the dealer. His only concern was about bolting the gear onto the ring gear carrier. Personally, I would think that would be a universal part. The ring gear carrier has a casting number 4063T with a JD part number AM3796T or AM1714T. Can you help?
Steve
- Site Admin
Post
by Lavoy » Fri Jun 08, 2007 3:42 pm
That part is the same, it is the gear set that has been changed at one time in its life, I will see what I have.
Users browsing this forum: No registered users and 240 guests
