1960 John Deere 440 crawler help
Jwadd
Post by Jwadd » Wed Sep 25, 2019 6:23 pm
Went to back up and heard a pop then gear grinding now it doesn't go into gear kind of pops out making a grinding noise
I am a complete newby where is a good place to start? Do I take the top off the transmission? Any help would be appreciated thank you so much.
Upstate NY
Re: 1960 John Deere 440 crawler help
Post by Lavoy » Thu Sep 26, 2019 8:11 am
That is probably the first place to look.
Jwadd
Post by Jwadd » Sat Sep 28, 2019 10:11 am
Took the top off the transmission. The shifting forks and gears all looked good. What should I do next? Do I leave the top off and turn the motor over to see if the input shaft is turning? Sorry for all the stupid questions I am as green as it gets with this
Upstate NY
Jwadd
Post by Jwadd » Sat Sep 28, 2019 1:18 pm
It stops grinding when I push in the clutch then starts again when I let the clutch out. Does that mean the clutch is still working and I need to look for something else?
Upstate NY
original possum
Post by original possum » Sat Sep 28, 2019 6:42 pm
I assume you mean it is grinding in neutral with the cover on. And by grinding you mean like putting it in gear with the clutch out. You need to see if any shaft is vertically or horizontally "loose". The best way to do this is with a hook bent into a welding rod. Hook each shaft (with the cover off) and see if it moves. There should be no visible (>about .015" ) movement. If there IS NO movement then, with the cover still off, slide the 2@R gear into 2 (rearward). At idle, let out the clutch and observe. Be ready to push the clutch in or you may get an oil bath.
Jwadd
Post by Jwadd » Sat Sep 28, 2019 10:48 pm
I will give it a try in the morning 😊 thank you so much for the help.
Upstate NY
Jwadd
Post by Jwadd » Sat Sep 28, 2019 10:49 pm
Upstate NY
gregjo1948
Post by gregjo1948 » Sun Sep 29, 2019 3:01 am
Does the machine have a reverser/shuttle?
Jwadd
Post by Jwadd » Sun Sep 29, 2019 7:36 am
Not sure I will post a pic of it
Upstate NY
Post by Lavoy » Sun Sep 29, 2019 10:08 am
It is not "going" into gear, or when shifted into gear it does nothing, there is a difference, and you need to be more specific when trying to diagnose based on description. Do you have a service manual for your crawler, you are going to need it.
Jwadd
Post by Jwadd » Sun Sep 29, 2019 11:00 am
The clutch is shot I can't figure out how to post a pic. Where's the best place to order a new clutch???
Upstate NY
original possum
Post by original possum » Sun Sep 29, 2019 12:15 pm
Not sure how we got from "pops out of gear" to "clutch is shot" but Lavoy is the best source of quality parts.
dtoots1
Post by dtoots1 » Mon Sep 30, 2019 7:51 am
Good idea to post your location in the profile, someone may be nearby to help!!!
Jwadd
Post by Jwadd » Sat Oct 05, 2019 5:31 pm
I could open the little view windows on the side of the bell housing and see pieces of the clutch not right. Going to pull the motor tomorrow and see can't figure out how to post a pic???
Upstate NY
Post by Jim B » Sat Oct 05, 2019 5:59 pm
This site has a dedicated picture server. You can read about it on the Messageboard Q&A and Announcements board. Info should be the fifth and sixth posts down. You need to send Lavoy an email at postmaster@jdcrawlers.com to set up an account with a user name and password. In the meantime if you email the photos you want posted to me, I will post them for you. Send me a PM if you do and I'll PM you an email to send them to.
Users browsing this forum: No registered users and 261 guests
