440i question
mavs1422
Re: 440i question
Post by mavs1422 » Fri Jul 05, 2019 8:53 am
Well finally got around to adjusting the reverser, I can snap into rear position now but didn't help. So I took the cover off on the lever side. I know what the problem is now, there are no shift collars on the front side. Does anyone have any shift collars? or maybe the dimensions of them so I could make some?
Re: 440i question
Post by Jim B » Fri Jul 05, 2019 10:40 am
He will likely see this, but send Lavoy a direct email (postmaster@jdcrawlers.com). He will likely have the best line on them unless someone happens to have some odd reverser parts around. Or you can try calling him during his regular business hours.
mavs1422
Re: 440i question
Post by mavs1422 » Fri Jul 05, 2019 11:56 am
Thanks Jim i'll send him a message.
dtoots1
Re: 440i question
Post by dtoots1 » Sat Jul 06, 2019 5:44 am
Glad you found the problem!!!! Will see what develops for your part, i call them shift forks and not sure if a person could actually machine them due to bent configuration from what i recall. I assume wheeled has a bit more access to the adjustment, my jd440ic does not leave room for good position to reach and adjust in particular the reverse position does not snap in and remain, even after adjustment, seems the adjuster will not turn further, so probably needs rebuilt, though she runs fine in forward and i use the tranny to reverse.
mavs1422
Re: 440i question
Post by mavs1422 » Mon Jul 08, 2019 1:27 pm
Thanks for posting the link B Town. I sent the seller a message to see if he has the shift collars.
mavs1422
Re: 440i question
Post by mavs1422 » Mon Jul 22, 2019 5:26 pm
Well I ended up making a shift collar and it works great! Now I know why it was missing, main clutch is stuck and forward reverser clutch is slipping. Guess i'll be splitting this in the near future.
dtoots1
Re: 440i question REVERSER
Post by dtoots1 » Mon Jul 22, 2019 5:39 pm
thats a shame. Though it would be a help to me if you can let me know what clutches etc cost when you get er done...
also can you advise if you had trouble with the little clutch adjusting wheel inside the reverser?? Mine seems to have bottomed out and probably indicates needs rebuilt, but would like confirmation. I have a spare but don't know whether working or not, but could tear that down to see what all in it and probably have to put in new etc...
mavs1422
Re: 440i question
Post by mavs1422 » Mon Jul 22, 2019 5:50 pm
I sent lavoy a PM to see if he has the parts to rebuild it. I'll let you know what it costs for parts. This is starting to be my new money pit lol
Re: 440i question
Post by Lavoy » Mon Jul 22, 2019 8:08 pm
Clutch discs are available, usually have some in stock. I have some used parts as well, plus bearings, and gaskets.
rolandj
Re: 440i question
Post by rolandj » Thu Aug 29, 2019 6:11 pm
I have a 440 ID 2-53 detroit . it has the direction reverser and forward is forward . Great machines .
