Lift cylinder seals..
So both my lift rams were leaking at wiper seal... I replaced the seals and the o-ring.. Both side.. When firing it back up any slowly cycling the cylinders it blew both wiper seal out of the Damn cast iron housing! ... Wtf! Is there a trick to this?... The left side I tapped back in and its fine.. The right side was missing a 1/4 of the plastic ring that lays next to the o-ring in the cast cap.. So it's leaking again.. Worse than before
Lavoy u got that plastic ring?? I can get the seals local there a national 471737.. Get them at any auto parts store.
Re: Lift cylinder seals..
Not on hand. Check with a local hyd shop, might be a common size.
Can you still get reseal kits for angle and tilt cylinders?
Out of curiosity only, I must have missed the first of this. What size crawler are you working on? Is this a bulldozer blade or a loader? Or????
Most kits are obsolete, I have been able to piece together the necessary parts in the past.
re..jirving machine..
tis a jd440 6 way blade
Users browsing this forum: No registered users and 585 guests
