40c steering problem
I adjusted my right side steering/breaking. Backing out of the shop everything worked like it was new, however, going forward and pulling back on the right lever, I hear a groan in front of the transmission and the crawler wants to stop. Any ideas what is wrong?
Re: 40c steering problem
Sounds like you misadjusted the right clutch/brake. The clutch must release first then, as the lever is pulled farther, the brake is applied.
Are you talking about the brake adjusting set screw? I thought about that, and will loosen it up today, if I can get out there before the rain starts. Thank you for your response, gregjo.
Before I go any farther, let me say this: on my 40c, the left final drive is off of a 420, and the right final drive is a 40c, however, the right final drive had broken some time before I bought it and was welded up. If that matters.
Now, I just provided more slack by loosening the brake adjusting set screw and backed it off, and it worked better, but there is still a little groan sound when using the right brake when going forward. Come to think about it, the groan sound been there since I bought the 40c. Still the right brake works great when backing up, but isn't as good braking while going forward.
I would like to get the right brake working better.
As far As the steering clutches, it is an adjustment issue. The groan sounds like the engine clutch slipping.
Users browsing this forum: No registered users and 166 guests
